holding the bonnet halves up
  • terryrscott
    • Mar 2022
    • 132
    Has anyone invented a good design for holding both bonnet halves up at the same time ?
    • 689
    Re: holding the bonnet halves up
    Not brilliant images as they're snipped from a video I took at Stoneleigh some years ago but they may help. Also, if the owner of the car reads the forum he/ she may be able to provide better detail.
    • terryrscott
      • Mar 2022
      • 132
      [ATTACH=CONFIG]12825[/ATTACH]
      [ATTACH=CONFIG]12826[/ATTACH]
      [ATTACH=CONFIG]12827[/ATTACH]
      [ATTACH=CONFIG]12828[/ATTACH]
      Thanks Jon, interesting pictures.
      • boustrophedon
        • Apr 2019
        • 89
        Mine came with little gas struts, unfortunately with both of them up, one or other does tend to fall down, perhaps stronger struts would work better.
        If I am working under the bonnet, I loop an old fanbelt over the studs.
          • 2814
          This was Bob Jacksons answer to the problem
          • terryrscott
            • Mar 2022
            • 132
            that looks a really good easy option , thanks to bob jackson
            terry
            • terryrscott
              • Mar 2022
              • 132
              hmm , the fan belt looks easy , i like the struts as well, thanks
              terry
              • boustrophedon
                • Apr 2019
                • 89
                My gas struts have definitely gone weak, I shall order some new ones when I have a little spare cash.
                • nightsurfer
                  • Oct 2018
                  • 123
                  The struts on my bonnet had zero gas in them and a previous owner had used a piece of plastic pipe cut lengthways to act as a wedge.
                  I swapped them out for these off eBay last year.
                  So far they have been great. 50N is plenty strong enough unless you're out in a very high wind.
                  • terryrscott
                    • Mar 2022
                    • 132
                    thanks very much , really handy info, i shall get them , just the job
                    i couldn't possibly see a picture of where / how they are installed could i ?
                    i think they look far more professional than pieces of rod.
                    • nightsurfer
                      • Oct 2018
                      • 123
                      This is the struts installed. Piece of aluminium angle on the bonnet and a bracket on the bulkhead.
                      (I'm not sure why, but the photo seems to have attached twice, even when I deleted the original and re-attached).
                      • terryrscott
                        • Mar 2022
                        • 132
                        Where could I find the ball ends , or whatever they are called,, thanks
                        • nightsurfer
                          • Oct 2018
                          • 123
                          They come on the Gas struts, just make sure you select the correct type when purchasing.
                          • terryrscott
                            • Mar 2022
                            • 132
                            Oh thanks , that’s unusual, the struts for my estate back door were just struts, thanks again.
