Light Bar - or headlamp mounts
  • duncan
    • Apr 2018
    • 137
    Can anybody share with me the best way to mount the headlamps???
    • 689
    Re: Light Bar - or headlamp mounts
    This is what is on my latest acquisition:
    However, I prefer the look of the headlamp on a light bar and have one on "order" to revert to the standard arrangement.
    • duncan
      • Apr 2018
      • 137
      Thanks for that - are the headlamps supported on the aluminium inner wings or is there some support structure under the wings
      With a light bar I would ask the same questions - is it bolted to the inner wings? - or does it bolt to the steel bars that support the wings?
      My "kit" has never been built completely and I simply don't have all of the parts so I'm making it up as I go along
        Generally bolted to the inner wings. I positioned mine far enough forward so that the radiator cowl could be removed by rotating it around the bar once the mountings were removed, thus not having to disturb the headlight alignment or the wiring.
          • 689
          Originally posted by duncan View Post
          ... are the headlamps supported on the aluminium inner wings or is there some support structure under the wings
          There is a bracket under the wing. I'll take photos later and post them here.
            • 689
            This is the bracket attached to the wing stay using the shock absorber bolt.
            The headlamp support has a removable panel to access the bolts into the bracket.
              IMHO, I liked the light bar on an early Alfa that had a raised centre section for a 'cyclops' light. Sorry, no pics.
