Ford Sierra mark 2 plastic master cylinder reservoir replacement
  • deanogrey
    • Jul 2021
    • 4
    Hi all - does anyone have one of these spare/available as the one on my Marlin Cabrio is leaking (or some guidance/advice on a sealant)? Cheers
    Re: Ford Sierra mark 2 plastic master cylinder reservoir replacement
    The reservoir 'Plugs] into the master cylinder via two spigots that go through a kind of o ring seal on the cylinder itself. No additional sealant is required or advised.
    Is your leak from that area or is the tank itself split?
    • deanogrey
      • Jul 2021
      • 4
      Sorry for not getting back to you sooner. The reservoir itself has a small hole in the top leaking a small amount of brake fluid. So if I could replace just the reservoir hopefully this would solve the problem. Trouble I’m having is getting hold of one of these Sierra based reservoirs!
      • martinclan56
        • Feb 2020
        • 486
        If there is just a tiny hole in the plastic I would be tempted to melt it closed using a carefully applied soldering iron.
        Cheers Robin
          Other Ford models have reservoirs that can be used - don't limit your search to just the Sierra.
          I researched this a few years back - have a look on Madabout Kitcars - massive long thread on dual brake servo, somewhere in there I found other suitable Ford reservoirs
          • deanogrey
            • Jul 2021
            • 4
            Thanks for the advice, looks as if i have lots of researching to do. Dean
            • deanogrey
              • Jul 2021
              • 4
              Hi Robin, never thought about this so I’ll give it a go. If it works it will be a cheap fix I’ve got nothing to lose. Many thanks Dean
                You could of course use a pair of remote reservoirs from the likes of Car Builder solutions together with the appropriate hoses/connectors.
                • kieran78
                  • Jan 2020
                  • 110
                  I have a spare mater cylinder with the plastic reservoir and big round black rear booster thing... Will post a photo tomorrow.
                  Yours for £10 plus postage.
                  • PaulW
                    • Feb 2013
                    • 38
                    Hi Keiran have sent PM Thanks Paul
                    • kieran78
                      • Jan 2020
                      • 110
                      Hi, have emailed you with photos.
                      • chrislibby
                        • Aug 2018
                        • 33
                        Hi Kevin. If you just want the plastic reservoir, I could use the master cylinder etc.
                        Could you pm me?
                        [email protected]
                        • kieran78
                          • Jan 2020
                          • 110
                          Hi Chris
                          Emailed you photos.
                          Kieran
