MkII seat belt mounts in a MK1 Roadster
  • martinclan56
    • Feb 2020
    • 486
    The seat belt mounting in my early Marina based roadster are primative to say the least. I would like to fit the arrangement used in the later models which uses inertia reel belts.
    I have seen a picture of the mounting in the later manual. Does anyone have a dimensional drawing? Or even better a set of the seat belt posts, used to mount the interia reels, that are surpless to requirements?
    cheers, Robin
    Re: MkII seat belt mounts in a MK1 Roadster
    I looked at this many years ago. Without removing the rear tub and welding parts to the chassis, I considered it too much effort.
    To be anywhere near ideal the mounting for the shoulder strap needs to be higher than the tub rim, at least higher than your shoulder to be anywhere near standard.
    • martinclan56
      • Feb 2020
      • 486
      Car looks like this at the moment. So I have full access!
      in_man-shed1 by Robin Martin, on Flickr
      I am making some other modifications to the chassis which require welding so now would also be a good time to improve seatbelt mounts.
      Anything must be better than the current arrangement my car has.
      Cheers, Robin
        • 688
        This thread has photos of the Marlin arrangement shown in the build manual: https://www.marlinownersclub.com/for...light=seatbelt
        Last edited by jon_wilkinson; 08-03-21, 03:35 PM. Reason: added snip from build manual
        • martinclan56
          • Feb 2020
          • 486
          Thanks - yes I have seen that. It doesn't seem beyond the wit of man to fabricate.
          Does anyone have any pictures of the actual thing?
          Cheers, Robin
            • 590
            Cheers, Robin
            If you follow the link in thread #4 from Jon, you will see a picture on the last but one post
            • martinclan56
              • Feb 2020
              • 486
              Thank-you. Missed the image the first time round.
              Cheers Robin
              • duncan
                • Apr 2018
                • 137
                Here in NZ the existing seat belt system was considered unacceptable - and we need the "ability" to fit a rear roll over bar
                (New build - 26 years old but never been on the road)
                So I made up a cross bar with verticals that a roll bar can be slotted into
                I will be using a four point harness - a standard lap diagonal will not meet the safety requirements - modern seat belts have explosive tightening devices!!
                • martinclan56
                  • Feb 2020
                  • 486
                  Wow - that is substatial looking! I have planned a few mods to my chassis but nothing quite that extreme.
                  Is the pole running through the middle part of the mechanism by which you can rotate the chassis? What is at either end?
                  Cheers, Robin
                  • duncan
                    • Apr 2018
                    • 137
                    Yes the pole is my rotisary
                    years ago I bought an engine hoist and it came with an engine build stand - which has been used for one engine and three washing machines so far
                    I modified it to be horizontal and a bit taller - that is one end of the rotisary
                    I weded a bit of steel tube onto the engine hoist - where it did not get in the way - and that is the other end of the rotisary
                    Then some crude brackets to attach to the front and rear bumpers
