Lucas Inertia Starter Motor for Marina Based Roadster
  • Ye Ol Ripper
    • May 2016
    • 298
    Hi Do you by chance have either a Lucas M35J or M35G starter motor in working order that you would be happy to sell on please for my 1800 B series engine?
    It has 2 bolt holes that are spaced 5" apart to fit it to the block. 9 or 10 teeth on the drive gear.
    My current item has a burnt out armature and is therefore not economical to repair.
    I am happy to fit brushes and end bushes if that's needed.
    Thanks for reading
    Re: Lucas Inertia Starter Motor for Marina Based Roadster
    From previous experience, always fit the correct correct drive gear to suit your ring-gear.
    Swapping a ring gear is a much longer job.
