Swb vs Lwb
  • dellboy
    • Oct 2020
    • 6
    Swb vs Lwb
    Hi hope this isn't a silly question Re Lwb Roadsters, what was the original purpose of extending the chassis was it driver comfort for lanky types or for 6 cylinder engine option and where abouts was the extra metal added, did it have any effects on the handling, Thanks
    Re: Swb vs Lwb
    The extra space was in the cockpit, so for the taller person.
    I have had both and the SWB can take a person up to 5ft 8ins.
    Anything above that you will be more comfortable with a LWB.
    I have not noted any differences in handling between both.
      Re: Swb vs Lwb
      You can usually spot the long wheelbase cars by the extension inserted between the rear of the front wing and the rear wing. So they didn’t have to make a longer front wing. See example here;
        Re: Swb vs Lwb
        Later versions had a one piece wing, but you are right , my LWB had the extra 6" as a filler.
        Some LWB had a dropped floor pan.
        John Brice, who is 6ft 4" has a LWB with the lowered floor pan and he sits below the windscreen.
        These are quite rare though.
          Re: Swb vs Lwb
          When I ordered my Roadster kit from Steve Himsworth at YKC I'm sure he said that the LWB version would become the 'standard' and the SWB was available as an option as it was deemed more suitable for those owners who might wish to enter trials events.
          • davidmartin720
            • 188
            Re: Swb vs Lwb
            I was told that the LWB was designed to allow a set of Golf Clubs to be carried!!!!!!!!!! David.
              • 1237
              Re: Swb vs Lwb
              That was the Cabrio/ Hunter not the roadster.
                • 930
                Re: Swb vs Lwb
                I have an outer wing with the 6" insert in my garage if anyone needs it they can have it for cost of delivery...
                • dellboy
                  • Oct 2020
                  • 6
                  Re: Swb vs Lwb
                  Thank for all the replies
                  • mikeyp
                    • Feb 2017
                    • 17
                    Re: Swb vs Lwb
                    Exactly that, when I originally bought mine I tried out both at the factory and being a 6 footer the LWB was a no brainer
                    1700 OHC marina based LWB roadster. HPH 415V
                    Kit purchased and collected from Plymouth circa 1988
                    Build completed early 1992
                    SORN for 15+ years until August 2020 + major rebuild / refurbishment commenced
