At last wing piping
    • 2454
    At last wing piping
    Well I bit the bullet and decided to put the wing piping on.
    So off with the wing
    Managed to take it off in one
    And one side done, the other side tomorrow.
    • 2814
    Re: At last wing piping
    A worthwhile job, looks great and finishes the car nicely
      https://www.eastkenttrimsupplies.com/ ?
        • 2454
        Now finished with new lamp bar in situ.
        Wiring tomorrow.
        • meverett
          • 662
          Looking good. Where did you get the stainless steel light bar?
          I too have two of these, a pitted chrome one and a painted one.
            • 2454
            I'll pm you
              Looks good, I hadn’t noticed it was missing!
                • 2454
                That's because there was so much crud caught in between the inner wing and body panels it looked like wing piping
                  • 590
                  Not wishing to pee on your parade but those indicators can not possibly be legal can they??
                    • 2454
                    Yep looked at that this evening, will push them out as far as I can. They were legal for the past two years in that position.
                      • 2454
                      This will be the position from tomorrow
                        • 590
                        That’s better.
                        when I first built my roadster I had indicators fitted directly below the headlights and it failed. I literally fitted an extended bracket to move them forward by 10 cm and the MOT guy was happy.
                          • 2454
                          This is why I love this forum, there is always someone to help.
                          Cheers matey.
                          That’s better.
                            • 590
                            Hi Adrian
                            This might help you with positioning. Always room for "interpretation" but as this rule was made in 1989 then I guess it is as relevant as can be.
                            This ruling also says you should have side repeaters fitted to a car registered after 1986 but my car was registered in 1987 and this was not a requirement then so there must have been a transition period where things changed.
                            Hope this helps get them positioned correctly.
                            Jon
                              • 2454
                              Just got back from my MOT guy to get the headlights realigned and he has repositioned the indicators so that it would pass an MOT.
                              He said that he didn't position them under the headlights as they may not be seen.
                              Anyway I went against the build manual and my lights are more forward so they can be seen better from an angle, second picture.
                              As it's registration date is 78 it doesn't need side repeaters.
                              Thanks for the information and the heads up.
                              Picture below
                              Hi Adrian
                              Jon
