Wanted. Ignition switch and light switch
  • twinstacks
    • Nov 2019
    • 81
    Hi. Looking for a light switch for my berlinetta. It’s from a mk3 cortina. Also need the black bottom part of the ignition barrel with the wires and plug. Anybody got anything available?
    Many Thanks
  • B_Williams
    • 115
    Re: Wanted. Ignition switch and light switch
    Many Thanks
    Good luck and let me know if you find two. I think they're made from unobtanium. Which particular light switch are you after?
    As regards the lock barrels, there's two sorts, one where the inner end it retained by a circlip; there are available as pattern parts.
    The other ones have the inner retained by a roll pin, and seem to be out of production; Guess which I need.
    Best Wishes
    Bill Williams
    Berlinetta
