Exhaust System Rubber mount
  • golfcharlie
    • Oct 2019
    • 1
    Greetings all from New Member Graham near Bristol.
    I am the new custodian of a Marlin Marina Sportster in need of two replacement rubber supports for the exhaust system. The present offending items are domed rubber blocks, each with one protruding steel thread. The Block is 5 cm wide with a domed radius of 3 cm. A transverse hole between to the two flat faces (distance between the two = 2.2. cm) is 0.9 cm in diameter.
    Any suggestions, please, as to where I might run these to ground?
    Many thanks for a pointer.
    Re: Exhaust System Rubber mount
    Have you looked at https://www.clampcouk.co.uk/exhaust-...g-rubbers.html
    Loads of pictures for comparison!
    • Kahawi
      • Jan 2018
      • 159
      Thanks Steve, what an interesting collection of handy items!
