Albert Dinger
  • dinger bell
    • Aug 2019
    • 17
    Albert Dinger
    Hi.
    I am looking for a spoke lookalike Compomotive rim - 205/60 R15 - 22mm offset. Can anyone help me get one or even two for spares. All costs paid. Regards Ray
    Re: Albert Dinger
    What bolt size and PCD, how many spokes?
    Pictures will help!
      • 688
      Re: Albert Dinger
      Also, what width rim do you need? Generally a 6.5" rim would be appropriate for a 205/60 tyre but it could possibly be fitted to anything from 5.5 to 7.5. If you are trying to match to existing wheels the width should be marked on the inside somewhere.
        • 1237
        Re: Albert Dinger
        The man is asking for a compomotive alloy as fitted to Berlinettas and supplied by Marlin back in the day. 6j x 15 inch .
        • dinger bell
          • Aug 2019
          • 17
          Re: Albert Dinger
          Hi
          I would get the you the info needed if I knew what you meant. PCD? Bolt size? You are dealing with an Ulsterman who has just upgraded from a pony and cart. Such is progress.
          Ray
            Re: Albert Dinger
            There re many sources for wheel terminology, this looks at first glance, quite good. http://www.offroaders.com/technical/wheel-terminology/
            Danny seems to know the particular pattern that you might need, as he apparently knows that you have a Marlin supplied Berlinetta, a picture would help everyone else.
            Do they have eBay in Ulster these days, or even a classic ford club?
