Wheel bearings
  • FranklinLeicester
    • 380
    Wheel bearings
    Does anybody have the part number for a Morris Marina 1.3 rear wheel bearing.Also, who is the most likely stockist?
    Franklin, Leicester
  • artrider50
    • 208
    Re: Wheel bearings
    Your local motor factor should be able to get them - I got front bearings recently next day no problem.
      • 2454
      Re: Wheel bearings
      I get all my parts for the Marina from All Parts in High Wycombe. They haven't failed me yet and are always reasonably priced.
      • f.swaans
        • 21
        Re: Wheel bearings
        The part number for all cars, not vans, is GHB 180. There is no difference between the cars from 1971-oct '75 and oct '75-on
        For the 10cwt van and pick-up the partnumber is GHB 127
          Re: Wheel bearings
          Message originally posted by: F PILKINGTON
          RE: WHEEL BEARINGS
          ANY GOOD ENGINEERING SUPPLIER WILL OBTAIN THE BEARINGS AT LESS THAN HALF THE COST IF YOU CAN GIVE THEM THE PATR NO OR MEASUREMENTS
          • FranklinLeicester
            • 380
            Re: Wheel bearings
            Thanks for all that, I've got it sorted out now courtesy of Fosse Bearings, Leicester. Oh, and Frans, thanks for that part number. All I've got to do now is do the ******* job!
            Franklin, Leicester
