Does anyone have a spare pair? Or perhaps know where they can be sourced?
Roadster front lower damper bracket (Marina)
Re: Roadster front lower damper bracket (Marina)
Pretty simple to get a Metal Basher to fabricate them locally.Originally posted by cryophile View PostDoes anyone have a spare pair? Or perhaps know where they can be sourced?MOC member since 05/97
Do you have one as a pattern? Or need dimensions?
There is a drawing from the late build manual fig 6 should help I think you could make it in two pieces each with its own flange if there is enough room between the wish bone parts after grinding off the boss.
But my knowledge of Marina front end is limited,
Last edited by b_caswell; 16-10-18, 10:47 AM.Ben Caswell probably not the last word on anything here!!
These what you are looking for?
Some more parts in my parts bin. Can’t remember why the holes are not the same on each, must have been odd bottom wishbones.
If you can or know someone that could fabricate a pair for you, PM me your email address and I will send you some drawings to scale.
Cheers, Martin.Last edited by meverett; 16-10-18, 05:35 PM.
Scan taken from the build manual.
Ah, now we know what you really want. The late Marina/Itals were factory supplied with a telescopic front damper. There were kits of parts that could be fitted.Originally posted by cryophile View PostHave a set, installed, but a friend wants a pair to upgrade a marina suspension. Lever dampers are a dying breed.
The dampers were not mounted in the same manner as the Marlin, but offset from the lower arm by a bolt on bracket.
There are still lever arm refurbishers for the old classic cars but I have not heard of one active for the Marina/Ital for years.
You would do better asking the Morris Marina Owners Club or on the forum Fastmarinamagazine.com
Somewhere I have pictures of the relevant home built brackets, I will try to find them later.
One resource in the US that might be able to help you is a Facebook group, Austin Powerless Racing.MOC member since 05/97
Know FastMarina well. Austin Powerless and 24hours of lemons are hilarious, never saw before. Getting tough to get stuff from the USA though. No Mark2s here that I know of. I'll keep trolling for someone parting out a Marlin. If someone has a drawing with measurements I can take to a welder, that would be very helpful. Thanks, Grant...
