hi would anyone have a gearstick for a 1850cc triumph dolomite please
gearstick for a 1850cc dolomite
Tags: None
Re: gearstick for a 1850cc dolomite
Are you looking for an early three rail or late single rail, presumably without overdrive?
Possibly worth phoning around the many specialist Triumph breakers in your area.MOC member since 05/97
If your not sure which box you have 3 rail the reverse is press and left forwards.
Single rail reverse is lift right and forwards.
May be able to help with a 3 rail gear stick but necessarily from a Dolly.Ben Caswell probably not the last word on anything here!!
