Roadster heater
  • meverett
    • 662
    Roadster heater
    I’m at the point in the rebuild that I have to think about installing the heater and matrix before finally fitting the dash and scuttle.
    Looking at the classic mini heater at the moment unless anyone else knows a better fitting one.
    Cheers, Martin.
    Re: Roadster heater
    That's what I used originally.
    It is quite bulky though & not hugely impressive. I eventually swapped to an early version of this...not a massive improvement in output but a little quieter and much more compact.
    Also had great service from T7, and I believe they are the manufacturers for a some of what Europa et al stock.
      • 2454
      Re: Roadster heater
      I went for this, small and excellent output.
      https://www.t7design.co.uk/products/...eater-12v.html
      Cheers, Martin.
      • meverett
        • 662
        Re: Roadster heater
        Great thanks, I will look into these.
        Cheers, Martin
          • 2454
          Re: Roadster heater
          I also purchased this
          https://www.t7design.co.uk/products/...-max-10-a.html
