Aerial location
  • billjackson54
    • 212
    Aerial location
    My radio doesn't work. I don't expect that's a problem at 50+mph as I probably wouldn't hear it anyway, but every now and again, in town or when waiting for someone, it would be nice if it worked. Not high on the list of priorities...other more important things to sort out all last year, but now, looking for causes of the problem I couldn't find an aerial. And then I did, under the n/s of the bonnet on the bulhead directly adjacent to the chassis number there is a threaded stud...but no mast. Hence no radio, as no reception....but I can't see where or how a mast could ever have been fitted as an ordinary vertical mast would stick straight through the bonnet (unless I drilled a hole????
    SO to my question. Is there a special type of aerial I can obtain to fit to this aerial base? Where do other Cabrios have their aerials fitted? What have others done?
    • 2814
    Re: Aerial location
    This is the aerial location on my Hunter, thin aerial went between bonnet edge and screen
    DC
      Re: Aerial location
      The aerial I have on my Landrover is fixed to the top of the screen inside the cab. Its quit unobtrusive apart from the red LED when the radio is on. It has an amplifier built in so it needs a power supply. It works better than any wing mounted aerial did. I'm getting one for the Roadster when I fit the radio. the wires will be glued down the side of the screen.
        Re: Aerial location
        Any ariel works best when fitted to conductive surface. The mast is generally an even fraction of the wavelength it is designed for, the metalwork acts like a mirror, doubling the effective length.
          Re: Aerial location
          As Landrover CB users know aluminium bodies do not make good ground planes. The centre top of a Marlin windscreen/roll over bar would probably be the best technical place , inconvenient though. My Roadster had the aerial in the engine room! Almost but not quite useless. stand by my windscreen aerial.
          • h_m_cumming
            • 766
            Re: Aerial location
            When I had a radio in mine this is where I had the aerial. Worked fine on am and fm.
            • stewartdjones
              • 86
              Re: Aerial location
              I have installed an electric aerial on the rear n/s of the boot, using an extension aerial lead and earthing to the rear chassis, if photo works see position
                Re: Aerial location
                Aluminium has a habit of oxidising to a very good insulator. RF is really fussy at very low voltages.
                • billjackson54
                  • 212
                  Re: Aerial location
                  The boot mounted electric aerial looks like the way to go. Where did you source the aerial from? Is there any reason I shouldn't site it on the off side behind the fuel filler (if there's room)? That appeals as I wouldn't lose any boot space that isn't already fairly in accessible?
                  • stewartdjones
                    • 86
                    Re: Aerial location
                    I purchased it from a car radio shop, I looked at fitting it on the o/s but if a spark occurred it could cause a fire due to the location of the fuel filler pipe.
                    I still have plenty of space inside the boot, mine is the opening type, I have two folding chairs stored inside along with all the other items like jack, pump, tools, water, etc.
                    • dave_kitson
                      • 269
                      Re: Aerial location
                      Hi - I fitted an electric aerial in just the same place as Stewart, and it has worked fine for 12 years. I bought it in Maplins as it was the only one I could find which would fit, those from Halfords, etc were too long underneath. My only regret is that I did not get a digital radio, as my favourite station is 6Music, which is digital only. Hence I tend to listen to the Mini Disk - anybody remember them???
                      Dave
                      • billjackson54
                        • 212
                        Re: Aerial location
                        As I started this particular thread, I thought I'd better document the solution. I changed my wheels....so that I might have a matching spare...but struggled to remove the luggage rack...one of the bolts is seized inside the sleeve and just turns. Without removing the rubber mounting through which the sleeve runs I cannot get enough welly on the tube to hold the sleeve firmly enough for the bolt to undo, so in the end managed to just remove three bolts and carefully wiggle and twist the entire rack through 180 so that the new wheel could be attached to the boot. While in the process I discovered a piece of co-ax wire with a broken crimp connector on the end dangling...and it dawned...at last....that in my car the boot rack doubles as the car aerial. I carefully made good the connection to the co-ax and attached it to the bolt connection to the boot...and hey presto the radio works....really rather well. I've fitted a unit without a CD as it fits centrally under the dash without fowling the heater box or damaging my knuckles when I select third and fifth...and I'm on the look out for a digital head unit that will drive a CD multi-changer that I can locate elsewhere.
                          Re: Aerial location
                          Genius! That is a great way to have an aerial.
                          Personally I think it would be a mistake to fit a CD player. They are so big and cumbersome compared to a portable media player (PMP) or digital audio player (DAP). Even the smallest will store dozens of CDs. I have used an iPod in the past but other more cost effective devices are available. My head unit has a simple USB connector that can easily be used to connect such a device. It can also be used to charge your phone if required.
                            Re: Aerial location
                            E46 Bmw's had a unit in the boot maybe look out for one on ebay.
                            Just an idea.
                            • scott h
                              • Mar 2013
                              • 670
                              Re: Aerial location
                              I intend to fit a windscreen mounted aerial such as this one, but stuck to the inside of the hard top of my Berlinetta. For soft top cars it could go under the scuttle or in the boot.
