Cabrio door lock release cable.
  • mike woodley
    • 121
    Hi everyone,
    I am in desperate need of a door lock release cable.
    Have tried breakers, e-bay, and even Ford! with no luck.
    It needs to be approx 72 cm long.
    Will other ford cables fit?
    Any advice appreciated.
    Thanks
    Regards Mike
    Re: Cabrio door lock release cable.
    Can you either make a replacement using a bike brake cable or join in a section of new cable with solder less joiners use the inserts that are in electrical choc blocks.
      I used a cable from at 2 door fiesta, got it from a scappy. The fittings are the same ( it was probably a 1990 Fiesta)
      • peterboat
        • Jun 2016
        • 232
        Originally posted by mike woodley View Post
        Hi everyone,
        Thanks
        Regards Mike
        Mike I have one which side do you need as its complete with handle
        • mike woodley
          • 121
          Hi Peter,
          Its the drivers door lock cable that's gone (offside)
          If you want to ring my mobile is 07763213288
          Regards Mike.
          • peterboat
            • Jun 2016
            • 232
            Hi Peter,
            Regards Mike.
            Off to the post office with the cable
            • dave_kitson
              • 269
              This is a bit of a minefield as there are several variables. Firstly, LWB Cabrios require longer cables as the doors are 2" longer than SWB. The cables came in several lengths depending on fitment - saloon, estate, front, back, etc - and were on Mk 2 Sierras (Mk 1 had different handles and used rods). The same type of door furniture was also used on other Fords of the time - Fiesta, Escort, Granada - so they are also sources of these items, and even more variety in cable length.
              Have a look at the earlier thread 'Cabrio Door Locks' from 17/8/16 for more info. Dave
