New Gearbox lever thread - revised
    It seems to me that the two pins(listed as one short and one long) that hold the bayonet cap just press in and one is longer and also locates the gear lever so is it possible someone has put them in the wrong holes ?
    • 2454
    New Gearbox lever thread - Please ignore previous ones
    OK let's try again.
    The lever has a sphere at the bottom with a grove in it which is used to align, see picture below
    There is a corresponding pin on the inside which it slides on, see picture below
    On my other two gearboxes this pin is on the oposite side and therefore my gear lever fits correctly.
    Obviously this one doesn't.
    The only explanation I can see is that there are two part numbers for the gear levers and in changing them they put the pin and slot the other way round.
    Heaven knows why?
    Any ideas?
      Re: New Gearbox lever thread - Please ignore previous ones
      My explanation was that the two pins have been put in the wrong sides
        Two duplicate threads deleted -
        Post from Ben Caswell moved to this thread. Note this is shown out of sequence because of the date/time stamp is too early.
          Would have been better to make no comment and rename this thread.
          I went looking to find the threads I should ignore.
          I should have ignored this one!
            • 2454
            Thanks Paul for deleting the threads.
            I made the mistake of pressing enter twice, I am sorry if this has caused any issues.
            I couldn't delete the thread even after looking at the FAQ section which implies it doesn't always work.
            I will take the virtual slap on the wrist and hope I don't do it again.
            • mocad2016
              • 111
              Thread renamed from “New Gearbox lever thread - Please ignore previous ones”
              to “New Gearbox lever thread – revised”
              To avoid members searching for unknowable unknowns.
              • meverett
                • 662
                Could the pins in the wrong way be that it is from the Triumph version of the gearbox?
                I think it is right as my gearbox is the same.
                  • 2454
                  Well there you go, it's a triumph extention, bugger will have to keep looking.
                  • meverett
                    • 662
                    Hi Adrian, I think the extension in your picture above is a marina one and looking at some mg midget gearboxes I think your lever is from an MG. Can the pins be turned around?
                    Cheers, Martin.
                    • meverett
                      • 662
                      Re: New Gearbox lever thread - revised
                      I may be looking for another Marina rear extension myself as not yet sure whether to use my extended extension.
                        Cut the lever off , turn it around and weld it back together . Problem solved?
                          • 2454
                          Now that's why we all need a sensibility check every now and again.
                          One can get very blinkered sometimes.
                          Good call.
                          Thanks
                            • 2454
                            I have pm'd you.
                              I have not yet checked part numbers, but who is to say that on some cars the driving position was not such a long reach to the gearshift as in a Roadster, and the gear sticks were actually angled a different way. There are certainly a range, mostly Triumph, of cars from Heralds, Dolomites TR7's, Marina and Itals that used the same single rail gearbox design.
                              40 years on, who is to be sure that the part you are looking at is actually what it purports to be!
