another update
  • darth vader
    • Feb 2017
    • 83
    another update
    greetings all
    well started work on the dash board, but not sure about it really considering making another.
    as you all well know space is of a premium and I am trying to shoe horn some sort of glove box for some limited storage, I am now thinking of leaving out the cutout
    curve at the bottom of the dash to give me a little more room I am also considering making it an angled dash to follow the contour of the top deck, any sugestions on dash
    design would be a great help.
    Darth vader
    • 2454
    Re: another update
    hiya the depth of the dashboard and the size of the steering wheel look like it might hamper getting in and out of the car.
    I would say goodbye to the glove compartment, I have, as I never used it anyway and utilise the space for other things such as diales and have put the windscreen wiper motor behind where you have your glove box to free up space on the bulkhead.
    I would also lose around an inch on the depth of the dashboard.
    Only my opinion, others will have a different idea.
      • 2454
      Re: another update
      utilising the marina diales
        • 2454
        Re: another update
        can anyone see the attachment?
          • 2814
          Re: another update
          I can't see it - invalid attachement ? ? ?
          Mike FWIW
          1 I've uploaded many Roadster dash pics into a gallery on this site, may give you some ideas
          2 As lister says that big wheel may impede getting in and out. KEX has longer seat squabs and a big wheel, makes it more difficult cos you can't get your feet under you(see pic)
          3 Keeping it where it is makes sense to me, maybe you could trim a bit off the bottom
          4 You may need the arced cutout to clear the gear lever NB KEX gear lever is on a custom made extension and further back
            • 689
            Re: another update
            Not showing for me. The link brings up an "invalid attachment" announcement.
              • 2454
              Re: another update
              have a look now
              adrian
                • 2814
                Re: another update
                Yes, that's fine now
                Rgds DC
                • darth vader
                  • Feb 2017
                  • 83
                  Re: another update
                  Nice looking dash,
                  my problem is I have a habit of wanting to monitor all engine parameters so I do tend to clutter the dash.
                  darth vader
                  mike
                    Re: another update
                    Darth Vader lovely dash but can you see the speedometer at 30MPH or don't you go that slow?
                    • darth vader
                      • Feb 2017
                      • 83
                      Re: another update
                      to be honest
                      road speed dont float my boat now my main employment is senior lecturer in motor vehicle however my previous work was flying so I could never get the same thrill on the ground as I do in the air.
                      as long as the car gets me to where I want to go in one piece and with exploding beneath me I will be more than happy.
                      Darth Vader
                        • 2454
                        Re: another update
                        Mike FWIW
                        When you say custom made extension is that on a type 9 or on a Marina/ MGB gearbox?
                          • 2814
                          Re: another update
                          HHmmm, here are pics, and just now I've checked the files that came with the car to find literature from
                          Hi Gear Engineering of Mickleover Derby about a 5 speed gearbox conversion for MG ZA/ZB
                          The doc also says the MGB can be accommodated and also mentions availability for a Type 9 box
                          The pics are from the mid 1990s - I thought it was just a gear lever extension, I really must get the car out to check if it is a 5 speed !
                          Gear lever has the standard knob, so no clue there
                          I've only done less than ten gentle miles in it, be great if indeed it does have 5 speeds
                            • 2454
                            Re: another update
                            It looks very much like a cut and shut to me.
                            I will look into it further over the weekend as I do have a spare marina box to play with.
                            Question now is do I use the spare I was saving just in case to see if I can get this to work?
                              Re: another update
                              It looks vert much Marina/Triumph, not Ford. So it's going to be a four speed.
                              I like the extension idea, not seen that before. Maybe there is a market for it, but it would require machining a standard box, but there are plenty of them around with knackered gearsets to experiment on.
