5-speed B Series - the Holy Grail
    • 711
    LT77 gearbox & 1.8 diesel B series on eBay here...item 322623672312
    The engine & 'box are not worth bothering with but the backplate & bellhousing are as rare as rocking horse droppings...find a TR7 5 speeder (usually cheaper than SD1 versions) and you can have a relatively "easy" factory spec conversion for your B series...tunnel mods aside..!
    Re: 5-speed B Series - the Holy Grail
    Could not agree much more.
    But was there ever a B series Diesel Roadster built. I think I remember in the distant past someone fitted a Nissan Diesel? I could be wrong.
    5speedmarina was killed off earlier this year there are quite a few Roadsters running the kit, but as with Frontline Developments and other Ford Type 9 conversions are still possible, but technically depending on the build there is no need for tunnel bashing.
    As always, any overdrive option makes the Roadster a joy on A roads.
    • davidmartin720
      • 188
      One person who had a diesel engine was Noel Pendock-Wheadon. This was the "Purple Peril" which is no longer around, if my memory serves me right. David.
        Purple peril gets mentioned a lot a lot in Roadster folklore. It would be nice to know it's history.
        Noel still lurks on this forum, or he did do until Dec last year.
