Bonnet Scoops
  • element
    • Dec 2015
    • 288
    Bonnet Scoops
    The current set up on the Lampredi twin cam we have is the standard Weber34ADF carb. Despite extensive research, I can't find a plenum chamber to fit it to enable a cold air feed. The engine suffers from lack of air under higher load.
    So, if I have no other option, I'll have to consider cutting a hole in the bonnet and fitting a scoop. If I have to do this - then I might as well go for a twin carb set up and do it right. Do folks buy scoops for such situations or make them?
    • 2809
    Re: Bonnet Scoops
    Have a look at Tech Tips Aug/Sep 2000 showing one way to make your own
    Alternatively rather than cut the bonnet, do you have room for example to have a "funnel" underneath at the front to collect cold ram air which could be ducted to the carb ?
    DC
    • element
      • Dec 2015
      • 288
      Re: Bonnet Scoops
      The problem is the current air filter is touching the bonnet when it closes. So when the air is sucked in - it only really comes in from around the sides of the filter and virtually nothing from the top (where the most efficient air should be drawn in). Not a lot of options...
      Sudden "LIGHT BULB IN HEAD" moment!!! staring me in the face all this time... Why not modify the current air filter and feed it cold air from down below as you suggest (which is what I have been trying to find a way to do). I am sure I can cut a hole in it and arrange a redesign of its function - instead of drawing warm air from around the filter... Close off the filter itself but for an entry tube with a ram pipe feeding it. No need to change the bonnet in any way - just modify the filter unit. ... Time to do some drawings...
      • chris_cussen
        • 684
        Re: Bonnet Scoops
        On my engine swap I used some trunking to a remote filter and put the air intake above the radiator so it gets cool air through the nose. The remote filter came from CBS and the trunking from Auto Silicone Hoses. There is a picture on this thread http://www.marlinownersclub.com/foru...an-engine-swap
        • Michael Turpin
          • 172
          Re: Bonnet Scoops
          Bonnet scoops sure do improve cool air supply
          Have a look at Pitstop mags - title of article is misleading but it does cover bonnet scoops
          Issue 196 October – November 2016
          A Gearbox change…………Part 1 Michael Turpin page 8
          the end result -
