Wheel nut torque
  • michael47
    • Oct 2016
    • 118
    Wheel nut torque
    G’Day All
    Today I took the front Wheels off to clean and polish them and as I went to put them back on I realized that I did not know the torque settings for the wheel nuts .The studs are so small compared to my other vehicles ,the Marlin is a 1994 YKC Marine based roadster and the wheels I think are Gemimi 5-1/2 -13’sa and the wheel nuts come with washers .Any ideas on proper setting I have set them for now at 50 lbs .
    Michael
    Re: Wheel nut torque
    Torque wrench settings are here or there
      You wasnt far out as the WSM says 48lbf/ft or 6.6 kgf/m is the spec for steel wheels as a guide. With alloy wheels its best to re check after first run out.
        • 931
        I've been using 42 lb ft
        • michael47
          • Oct 2016
          • 118
          Thanks guys I think I will go with 43when I re do them after a 100KM run.
          Michael
