Re: Roadster Rebuild Diary from Cornwall
Good point Ben, many thanks. Just checked the bolts that I had removed and they all have spring washers so I had better look for a copper washer. When I removed the bell housing there was a fair bit of silicone that I had to clean up, as the oil seal had failed the last owner decided that was best instead of replacing the seal and gasket. I have also noticed that they misplaced one of the laygear springs as well so I have ordered one of those. I now feel the need to remove the final drive flange to replace that oil seal and while I am at it remove the rear extension to replace that gasket. Getting the final drive flange off is proving to be a challenge though.
