Identify hoses?
  • Michael Turpin
    • 172
    Identify hoses?
    Can anybody help with the identification of these hoses they are identical and fit in my brothers Robin hood and need replacing. as you will all know motor factors these days need a reg/model/Yr before they tap it into a computer.
    So Here's a challenge.
    Many thanks Michael
    • 1237
    Re: Identify hoses?
    Hi Mike, Looks like a Cortina mk 3,4 or 5 top hose
    • dave_clutterbuck
      • Jun 2012
      • 260
      Re: Identify hoses?
      I had the same problem last year, no motor factors held any stock to compare.
      I ended up buying some Vulcoflex hoses from Car Builder Solutions, they should have the correct length of hose to suit
      Good Luck
      Dave
      • philcoyle
        • 379
        Re: Identify hoses?
        Look a bit like Granada/Sierra top hoses. QH 1939 is a number that comes up in my collection of parts, I always use generic preformed angles and bends and diameter, and then fit them together with stainless tube. Make your own its easier with all the many designs and configurations owners fit on their cars, they won't hang you for it!.
          • 931
          Re: Identify hoses?
          I think that the one on the right is a cortina bottom hose pump to radiator. You should be able to find one on ebay
            Re: Identify hoses?
            I just used these people: http://www.autosiliconehoses.com/sil...hose-shop.html (See my rebuild diary). Huge selection of hoses, joiners, pipe etc. Delivery was in 2 days from order.
            Chris
              Re: Identify hoses?
              You can try here. http://www.oldpartstore.net/ they have lots of Mk3 Cortina bits (links beneath pics).
              radiator-hose-top-ohc-09-73-.jpgRADIATOR HOSE TOP OHC 09/73-
              radiator-hose-bottom-08-73-.jpgLOWER RADIATOR HOSE 08/73-
              • Michael Turpin
                • 172
                Re: Identify hoses?
                Thanks one and all problem sorted
