Roadster Front suspension parts req'd
  • mark kessell
    • Apr 2012
    • 24
    Hi All
    I am looking for a marina front suspension arm that fits on the l/h torsion bar
    Need both parts ( metal and cast ) as i have damaged one on my car
    If you can help please message me or call 07933 380222
    Happy to pay going rate
    Many Thanks
    Re: Roadster Front suspension parts req'd
    Not sure quite what damage you have done, but the usual failure is corrosion between the upright and the trunnion.
    It is possible to fit a Walford trunnion that cuts its own thread.
    As I am currently (allegedly) not an MOC member, it's lucky I can post this advice.
      I may have misunderstood can you identify the parts
      here or there
      It may be that part 37 has been twisted as a part of accident damaged, as identified on other incidents.
      • mark kessell
        • Apr 2012
        • 24
        Hi Steve ,
        it's the arm that's attaches to the torsion bar that the upright bolts too, as i have bent mine
        thanks Mark
          • 2797
          Mark
          Try this pic, is it the passenger side you are talking about ? I probably have used spares for both sides anyway
          E mail the info on exactly which bits you need to me at home, my details are in Pitstop
          Dave Cunnington
            • 2797
            This is drivers side , also from the front, before hub etc goes on. It maybe easier for you to see the parts detail in this pic
            • mark kessell
              • Apr 2012
              • 24
              Hi,
              thanks for for the photo
              its the lower arm arm that attaches to the torsion bar and comes out to meet the front upright and is connected with a trunion
              it's 2 parts that bolts together
              many thanks Mark
                Here is a start,but ouch at that price.
                  • 2797
                  Mark, as per post #5, get in touch if you want help
                  I don't know if they are handed, so which side of the car is it...............................and I shall need your address to send the items
                    The only parts that are handed on the front suspension, according to the parts list are:
                    Item 37 Pin and stub shaft swivel/Steering, suspension upright
                    Item 45 Trunnion/Lower Swivel pin
                    Item 60 Steering Lever
                    I reiterate, if the lower arm assembly has been accident damaged, Items 1 and 2, I would suspect that the Steering suspension upright may also be twisted.
                    • mark kessell
                      • Apr 2012
                      • 24
                      Thanks Dave that's great regards Mark
