MGF Front discs
  • stephenlilley
    • 102
    MGF Front discs
    I have just finished fitting MGF rear discs to my Roadster and wondered if anyone has fitted MGF front discs. It looks as though it should be relatively straight forward or am I missing something? The latter is very possible !!
    Thanks
    Steve Lilley
  • CompoSimmonite
    • Jun 2013
    • 318
    Re: MGF Front discs
    Brilliant idea. I've found original spec Marina discs are getting expensive so intended looking into alternatives that would fit over the hub and either MGF front or rear are ideal as it's save me having to redrill Fiesta, etc discs to hub Marina PCD.
    If you check out the Brembo web site you can find exact technical drawings of the discs.
    Paul h
      Re: MGF Front discs
      MGF front discs have the same PCD but when I looked at them the offset of the disc to its mounting was too different.
      Thats why I went down the Renault Clio route, a mod that has been followed by several Roadster owners as well as Marina owners.
