engine mounts/supports 2.0l pinto
    hi all
    looking for a pair of engine mounts for a 2l pinto lump in a berly, will any do with a 3mm base plate mounted on the the integral chassis supports? possibly with a piece of angle welded to the underside to strengthen the plate!
    the support currently is an oval shaped one with lips pressed in!
    • 1237
    Re: engine mounts/supports 2.0l pinto
    Tony yours is a Sierra Berly so different to a Cortina based model The arms are Sierra and the type of rubber mount is shown fig 2 in the build manual. However up to you as you could make up something similar.
      thanks danny, yeap, thought of an oval plate with a bolted (top and bottom) rubber pad as available on good old ebay - early ford pieces being a bit like hens teeth!!
