Another Marina brake problem
  • element
    • Dec 2015
    • 288
    Figured I'd start a new thread on this...
    Despite passing the MOT yesterday, on the drive home from Perth, the rear drums began to make a groaning noise. I'd touch the brake pedal & it'd stop. Only to start again shortly afterwards.
    Today I jacked it up, removed the wheels and the drums. The offside brake piston had leaked fluid all over the shoes & they were clearly not binding against the drum. By contrast the other nearside drum outer paintwork (red hammerite) was discoloured to a brown around the outer edge; it must have got pretty hot for that to happen. It otherwise seemed ok no leaks.
    So I began to strip the offside brake components and now have the shoes removed and the pipes removed from the back & the handbrake disconnected too. I am stuck on removing the actual piston... I removed a rear rubber boot which was around it and there seems to be a flat metal rim on the area where the pipes screw in..? Can some kind Soul illuminate me on how to remove the piston from this stage?
    This looks like a replacement part.. but I think I need to measure the one I have to be sure...
    Buy and sell electronics, cars, fashion apparel, collectibles, sporting goods, digital cameras, baby items, coupons, and everything else on eBay, the world's online marketplace
    I think I will replace both rear pistons and shoes in one go..
    One step forward, two steps back...
    Re: Another Marina brake problem
    On the back of the cylinder you removed a rubber dust boot. The cylinder body passes through the backplate, it is designed to slide and is secured by two Spring clips looking exactly like these here normally hidden by the dust boot.
    But just a reminder that parts lists and workshop manuals are available via the link in my signature below.
    • element
      • Dec 2015
      • 288
      Ok thank you - I got it now; the two clips go front and back inwards to make it look as though they are one continuous ring.. I'll go and get another go this afternoon...
        There's a thread on here from last year when I rebuilt my marina brakes both sides, lots of useful pics and comments.
        • element
          • Dec 2015
          • 288
          Ok, thanks, I'll look for it. Parts ordered and due to arrive next week...
