****** Cabrio door locks.
  • norman ball192
    • 8
    Hi All,
    The near side door lock on my Cabrio was not responding to the key, so I removed the inner panel and adjusted the links between the key/lock & the mechanism, and all worked fine, from the near side BUT the drives door then stopped working, with the electric plunger dropping down, but then rising back to the top, and not stopping at the bottom of its travel. I assume this is due to the polarity change from the other lock???? No amount of link adjustment makes any difference. Has anyone got and suggestions???
    Regards Norman.
    • 1650
    Re: ****** Cabrio door locks.
    Thats interesting. My Hunter has always had the same problem as your first sentence. Never sorted it so will follow this post with interest. Peter.
      Never bothered with door locks, usually got the roof off so anything then is stealable is in the locked boot
        • 931
        Door locks and a boot? ??!!!
        • Gareth
          • 502
          Well I never....
