Mk2 wing stays
    • 2449
    Mk2 wing stays
    Hi all
    Once again I am trying to fit the inner wings.
    Below is a picture of my wing stays.
    There appears to be a couple of versions and mine required you to fix the top to the damper and then line up the wings stays so they were horizontal and then drill hole and bolt through at the bottom.
    My question is, did the stays come with the top hole pre-drilled so the siting and drilling of the lower hole would be a doddle.
    Or did you have to drill both holes?
    The reason I am asking is that I am coming to the conclusion that the stays are set to high.
    Hopefully someone can delve into their memory banks and answer the question.
    Re: Mk2 wing stays
    I maybe wrong but I recall having got drill them. Many hours of twiddling with packing and a level before the final decision though!
      • 2449
      Re: Mk2 wing stays
      Hiya
      I am now questioning every thing.
      Laying the inner wing lightly in place and tucking it under the outer wing you can see from the picture that the top of the cut out leans on the top of the suspension arm.
      Any movement up and down means the suspension pushes the inner wing up.
      I am now officially frustrated.
      Two weeks and still no further on.
        Re: Mk2 wing stays
        Who made the cut out? Factory, you?
        You can enlarge it as long as the fibreglass cover still covers the hole.
          • 2449
          Re: Mk2 wing stays
          Yep that's my quandary, it was a factory supplied wing with cut out.
          Came with kit.
          Someone must know a trick or two to get the buggers to fit.
          I have tried to cut the other wing and have ended up with a friend of mine (metal micky) welding it back to how it was supplied as the cover wasn't big enough to cover hole.
          Oh well, have had enough for today, so pack up and re-think.
            • 2797
            Re: Mk2 wing stays
            Not seen that type before. Interested to see a side on pic to look at the damper bolt area.
            Each Marina Roadster I've worked on has the struts that attach only on to the two bolts below the top suspension bolt, see pic of Q67 (black) and Q249(green).
            Q249 is 21477, your MHG I believe is 21427 so they are not too far apart by kit manufacture date, Q67 is 21027.
              • 2449
              Re: Mk2 wing stays
              Hiya
              Below is the more modern instructions like the ones in your pictures.
              And below from the original instructions from my manual
                • 930
                Re: Mk2 wing stays
                I don't think you're far out. It's very close to the top wishbone on mine so close in fact that it must hit occasionally because the top of the hole in the inner wing is bent up a bit.
                Don't forget that the inner wing will bend up in the middle when the front is clamped to the bottom of the nose cone where you seem to have quite a gap in your picture.
                  • 2449
                  Re: Mk2 wing stays
                  Do you think I should bolt the inner wing to the outer before I bolt to the body?
                  • lil_red_roadster
                    • 710
                    Re: Mk2 wing stays
                    I had the later(?) stays but as I said up-thread it was hell's own game to make the wings fit.
                    As well as having to relieve the outer wing adjacent to the A post the stays needed cranking to a) get a decent alignment with the outer wing and b) reduce the height. And I still ended up slotting the holes to achieve the final fit.
                    As for the first 2 holes being the same as the bonnet side - forget it. First one yes, but the 2nd was out by 1", enough to justify it's own hole
                      Re: Mk2 wing stays
                      Hope you have checked the for and aft play of the Mini top wishbone as per my notes in Pitstop. Much easier to play around with spacers etc when you have access from above.
                      If an MOT inspector spots it, it might be a fail or at least an advisory.
                        • 2797
                        Re: Mk2 wing stays
                        Well, you learn something new every day, I'd never noticed it !
                        I've just looked at the build manuals I remastered some years ago and the early one has this page - note how it tells you to attach the wing :
                          • 2449
                          Re: Mk2 wing stays
                          Will try tomorrow and let you know.
                            Re: Mk2 wing stays
                            The top hole was predrilled on mine for the hybrid, after hours of struggling I finally decided to re-drill them in position to fit. Later when I mentioned this to PM he said "OH yes they were drilled incorrectly. Best bet is to get the chassis level across the car then set up the wings on blocks on top of the wheels and use a long straight edge across the wing tops with the level to ensure the tops of the wings are also level. Then offer up the brackets to suit.
                            • dbazdavies
                              • 409
                              Re: Mk2 wing stays
                              I remember having a real job with the wings trying to fit them as per the factory idea - inner first then wing to inner - so I fitted wing to inner then to the car !!!
