A new thread about a clutch arm !
This topic is closed.
    • 2814
    Failed, see pic ! Peter's Dolomite one was just too big - so I'm back in the market for one PLEASE !
    Re: A new thread about a clutch arm !
    Interesting. We're the springs different dimensions too?
      • 1649
      As a possible fix to get you mobile could you make a couple of cuts at 45 degrees, press the ears together, then weld up? Peter.
        Or a the dolomite uses the same gearbox style, try a dolomite thrust bearing carrier?
          • 2814
          Good thoughts guys, thanks. All ideas being examined
            You could swap the springs its only a rivet
              • 2814
              This time the job is definitely done. Peter Bailey found me a correct part, which is now fitted, many thanks (again) Peter.
              On the previous thread a NOS one was found on ebay USA, it's now arrived (still in in it's original BL blue box) and is safe in my spares holding.
              SG : FWIW I haven't compared sizes of Dolomite and Marina release bearings and sleeves.
              Thanks again to all. Thread closed
              Rgds DC
