Winter Maintenance
  • Gareth
    • 502
    #16
    Re: Winter Maintenance
    Originally posted by phil.coyle View Post
    Do you think it's terminal?
    I'm positive it's terminal, sorry to be so negative...
      #17
      Watt he needs is a bit of ac/dc to lighten his life
      • philcoyle
        • 379
        #18
        'ere why don't we all go on that TV show only connect!
        • Gareth
          • 502
          #19
          I won't make any silly comments on here.
          I'm going home for Christmas, and it's red lights all the way....
          All the best one and all,
          Gareth.
            • 876
            #20
            I did hear that he had a discharge from the Leclanche cell , He was met by Milli Henry and they jumped on a Killocycle sparked it up and rode off over the Weatstone Bridge.
              Enough he cried
                • 2824
                #22
                Dogoncrazy is visiting and we looked at this thread..............................Watt, I'm still feeling wired - can't believe I'm being discharged ?
                This has potential to run on, but currently I've run out of sparks of inspiration
                  • 876
                  #23
                  I believe that you are impeded by a temporary lack of capacity.
                    try jumps to gain a lead on the starter!
                    • scott h
                      • Mar 2013
                      • 670
                      #25
                      Spaghetti Cabrio-nara.
                      • Alan B Gloucester
                        • May 2012
                        • 92
                        #26
                        Watt, about Arc the Herald engines sing, or would that be sung flat, & quietly, maybe conducting rage against the machine. I'm wired for sound but still staying neutral I'm wiring board now. Still it's better then last year's Dyer/Rea. C u.
                        • ggrum
                          • 785
                          #27
                          All this hertz my sense of humour! I blame Ben for starting it.
                          • lil_red_roadster
                            • 711
                            #28
                            Resistance is futile.
                              but does he have the capacity to continue?
                                Its my dynamism that keeps me generating replies !
