stiff 2nd gear mk1 2.0
  • Rfc1drew
    • Oct 2015
    • 21
    Hi all,
    As iv only had the marlin a couple of weeks my plans (sure we all have these) are to sort a new interior and paint etc, one thing bothering me is 2nd gear, their is no unusual noise from the box but it can be a mission to get 2nd to slip in especially when on the beans. Is their something simple like an oil change that may solve this or is it a rebuild.
    Ps going to send for the tech tips manual !
    Re: stiff 2nd gear mk1 2.0
    You cant rush the Triumph box at the best of times probably the synchro ring is a bit tired but that means rebuilding the box If its not making noises I would try and live with it for a while. If the car has overdrive don't use additives in the oil....If you are having trouble finding the gears rebuilding the remote gear change may improve things a bit.
      • 1648
      I would certainly do an oil change with OE spec oil. A build up of microscopic "wear" material in used oil will only tend to worsen the synchro cones ability to grip the cones on the gears.
      • Rfc1drew
        • Oct 2015
        • 21
        Great thanks guys, I'll do an oil change on the box and see how that goes what oil would you recommend
          • 1648
          Not familiar with the Triumph stuff but in principle I would go for whatever oil was originally specified for the car that the gearbox came from.
            Try to find a GL4 90ep(Castrol Classic) as there is an opinion that the later GL5 attacks the bronze parts(synchro rings) difficult to prove as replacement rings seem to be inferior quality anyway.
            • Rfc1drew
              • Oct 2015
              • 21
              Thanks guys that's the interior all out so now to see what happens
