4 bar link rear end !!!
  • dbazdavies
    • 409
    Has anyone fitted a 4 bar link to a roadster using the Marina axle ??
    • 1648
    Re: 4 bar link rear end !!!
    Have a look at this link for Madabout / Aquila. Scroll down to Rear Suspension. Peter.
    http://www.madabout-kitcars.com/?shownews=65
      I think one or two have been converted but never seen one in the flesh.
      Shouldn't be too difficult though, e.g. using existing spring mounts for the lower bar and an unequal length upper with a bracket welded to the chassis rail.
      Diamond axle brackets are widely available for Escorts and could be adapted.
      You'd probably want to turret the coil-overs and add a Panhard or Watts linkage for lateral support.
      Where there's a welder there's a way..!
      Or maybe go for something like the Hoyle setup for the MGB - a complete subframe that bolts in and provides full IRS & Sierra diff.
      • dbazdavies
        • 409
        Thanks guys was thinking of the escort one frm Peter Lloyd Rallying !!!
          When I bought my first Dolomite Sprint axle I did consider leaving all the original suspension brackets in place and using the complete Sprint set up with turreted springs and shocks. It really was a bare chassis modification, and I was unsure whether all the work was worth the end result.
          But, in some ways I regret not doing it.
