Gearbox Swap
    Re: Gearbox Swap
    That definitely needs more support, not just relying on the ally flanges and the attachment of the floor board.
    • h_m_cumming
      • 766
      #17
      Re: Gearbox Swap
      This was how I did mine on my 2L Fiat engine and box. It' handleing 150hp OK and seems to work well
        • 930
        #18
        Re: Gearbox Swap
        What did you use to strengthen the floor?
          • 930
          #19
          Re: Gearbox Swap
          Yes, it'll have a length of steel angle above the floor board which I s bolted to the tunnel
          • h_m_cumming
            • 766
            #20
            Re: Gearbox Swap
            My floor is 1/2" ply bonded and bolted all round. I put spreader plates on the inside.
            Just looking at it now I must get the ends of those bolts cut off!!
            I looked at it that since the origional marlin design just bolted to the tunnel then this had to be stronger.
              • 930
              #21
              Re: Gearbox Swap
              I haven't given up, honest! Just had a lot on recently so I've not been able to get into the garage. What's concerning me at the moment is the clearance between the bulge (I can't think of a better description) for the starter motor and the end of the tunnel. I remember that it was close before but it seems to be closer now but I can't figure out why
                • 930
                #22
                Re: Gearbox Swap
                Here are a few pictures...
                As you can see there's next to no clearance. Considering that the engine is in the same place and the bell housing is the same I can only think that it's the angle of the gearbox in the tunnel. I can improve it by moving the tail of the box over toward the passenger side but then it's not in line with the diff flange and I cant get to the filler plug... The other thing that makes it look better is dropping the back of the gearbox down, but then the engine will be at something like 5 degrees. Any ideas?
                  • 930
                  #23
                  Re: Gearbox Swap
                  Ok, so I managed to use a leaver to move the engine and box about 1/4" forward to get clearance to the floor. Then I drilled the oles in the floor and fitted the angle inside the car to help spread the load. Here's a couple of pictures from inside the car...
                  Having got it all put back together James and I went for a run out to Windsor and back, which was great fun :-) There were no nasty transmission noises so I'm a very happy Marliner!
                    Re: Gearbox Swap
                    Presumably you have not left the engine mounts under permanent tension.
                    The fifth gear overdrive is an excellent improvement.
                    Are you still running the standard Marina 3.63 ratio rear axle?
                      • 930
                      #25
                      Re: Gearbox Swap
                      The engine mounts weren't under tension, they had settled back if that makes sense so they were pushing the engine backwards so the engine is now back in its original position as near as damn it.
                        • 930
                        #26
                        Re: Gearbox Swap
                        PS and the moral of the story would be to take some measurements of the existing installation before getting over excited and pulling the old gearbox out!
                        And yes I'm still running the 3.6 diff, the overdrive 5th gear does make a big difference
                          • 930
                          #27
                          Re: Gearbox Swap
                          Having run it for a year now the box has started making noises like the bearings are shot so it's got to come out again. Why does this happen just as the weather gets better????
                          The plan is to get it out tomorrow, rebuild it next weekend and refit it the week after.
                          I'm hoping to get it all done by the next SHEB meeting.
                            • 930
                            #28
                            Re: Gearbox Swap
                            Needless to say it's not going according to plan. Spent all of today stripping it down, on several occasions where the instructions said "slide it off the shaft" a deal of force was required. Found that both the input and mainshaft bearings are worn so I've ordered the parts ready for a rematch next week.
                              • 930
                              #29
                              Re: Gearbox Swap
                              Got off to a good start on Friday morning and by about 2pm I had the main shaft reassembled and installed in the gear case along with the countershaft. Then I started to fit the 5th Gear and spacer onto the countershaft only to realise I hadn't fitted the bearing retaining clip. OK, not a big problem just remove the gear and fit the circlip. Well that's when things went wrong. The gear came off with a bit of bfi but so did the spacer which made a bid for freedom! I didn'the see the going of it and it was nowhere to be found.... have to wait a week now to get a replacement and finish the rebuild. Frustrating... grrrrr.
                                Re: Gearbox Swap
                                In my case parts that make a break for it usually hit my shoe and go right under the bench where all the junk is stored.
                                Come on Andy its out there somewhere!
