Fitted a Power Socket
    • 931
    In preparation for the C2C at the end of the month I decided to wire in a power socket so that I can power my phone while it's playing at being Mr Sat Nav
  • mark westbrookwhite
    • 146
    Re: Fitted a Power Socket
    I fitted a triple socket under the dash as my phone is playing at being Mr. speedo The Triumph one has given up the ghost and they want £75 to refurbish it.
    The other two sockets are for my TomTom Sat Nav. and my GoPro camera. I hope the battery can cope with this lot!
      I added a socket, then rewired a trickle charger in the roof of my garage and used the socket to keep the battery charged. Useful as it did not mean removing the engine cover to access the battery, and an obvious reminder, when you got in the car, that the charger was connected.
      The idea might not suit everyone, but it worked for me.
        • 931
        That's a good idea
          That's the first thing I put into the Marlin when I got it.
            Originally posted by andyf View Post
            That's a good idea
            Charger was plugged into a twin socket directly above the cockpit, secured by a cable lie so it didn't fall out, the cable was pretty obvious as I wrapped it in yellow spiral.
            Alongside the charger was a socket for an inspection lamp, it was always available with no cables dragging on the floor or trapped under a tyre.
              Steve
              Having a dash mounted plug-in charger socket sounds interesting. I already have the cigarette lighter socket - where did you get the plug to go into the socket that connected back to the charger?
              Also like the idea of a twin 240v socket suspended from the garage roof - less cables trailing over the bench and in the way of walking around the car. Good idea.
                Steve
                No idea now exactly where it came from, my first guess would be in my 12v rummage box, possibly a rewritable one from an old inverter that was subsequently hard wired.
                ebay must be a source, but what do you call them.
                the ow side to the installation is that when the car is not in the garage you have to dodge around a couple of hanging cables at chest height.
                  Hi Mike, cigar lighter plugs are readily available - you would just have to cobble together a plug and socket to replace the croc clips on the battery charger. In fact, chop off the croc clip leads and put a fag lighter plug on then get a female fag lighter so you can still connect the charger in the normal way. Total cost about a fiver.
                  • old_n_notpastityet
                    • Apr 2015
                    • 197
                    I got a power socket with crocodile clips on,routed it trough bulkhead by battery compartment and a triple one with usb to plug into that. then when we go out just connect the clips to the battery then we got power for everythin..
