Sierra based Cabrio Brakes
  • bryannewell
    • 331
    Hi folks
    After replacing leaky Master Cylinder and then attempting to bleed the Brakes I now need to renew wheel cylinders and as a consequence of that now the short
    lengths of brake pipes that fit to them
    I have 3/16" copper pipe but what has come off is a different material(Harder but not steel) can anyone shed any light on what this is likely to be? and would it be a problem to replace with normal copper?
    Bryan
  • philcoyle
    • 379
    Re: Sierra based Cabrio Brakes
    It is most likely Kunifer Pipe, it's used a lot in car restoration. The copper pipe is easier to form but I like the strength and rigidity of the Kunifer.
    You can form it with your brake pipe making kit just make sure it's clamped in the formers really tight, and have 3 shredded wheat for brekkie.
      Yep - almost definitely Copper is very soft Kunifer is a mis of copper nickel and iron (hence ku (Cu) Ni Fe) Mostly copper but with other metals for strength etc. I would always recommend a pipe bender (even a cheap one will do) rather than trying to bend by hand - it always goes well till the last second! - and get a proper pipe cutter too - a couple of quid. It is of course quite ok to replace the pipes with plain old copper, much easier to form but again use a pipe bender for neatness and avoiding it kinking.
        • 1648
        There has been a lot of discussion recently about kunifer on the Madabout forum. Well worth a read. Biggest problem with pure copper is that it work hardens (so becomes more brittle) with age / vibration which is why kunifer was developed. Peter.
        • bryannewell
          • 331
          Thanks guys
          That sounds like it
          As said I do have copper left over from a previous Roadster rebuild but when I went to form some flares I broke the Flaring tool Die(teach me to buy cheap!!)
          Looking into some pre made stainless flexibles at the mo
          Will post what I decide to do
          Bryan
          • bryannewell
            • 331
            Just to follow up
            Decided to go with stainless flexibles after finding a website for a company called HEL
            Great site where you can customise to suit,picking length,adding end fittings,sleeves,bobbins etc even a large range of coloured finishes all at the touch of a
            button with visual display where you can see it go together as you choose
            Very pleased with the result
            Bryan
              • 1648
              Hi Bryan. Off topic completely but I have sent you a PM about your ignition switch - re Pitstop European Tour article. Peter.
