Fuel Filler Advice
    • 930
    Fuel Filler Advice
    I'm going to have to reposition the fuel filler on my car. The MX5 anti-surge valve works to a point but when driving enthusiastically petrol is still leaking out of the filler cap. I'd be interested in seeing pictures of how other Roadster owners have fitted their's.
    Re: Fuel Filler Advice
    No sure if this helps as mine looks to be rather low down and looking inside the angle down to the tank is very slight so I'd be surprised if I didn't have fuel sloshing back up to the filler cap.
    btw. Wish it still looked this smart!
      • 2809
      Andy, I don't have a pic of the back of your car but do you have a very low filler ?
      If so, look at old Pitstops/Tech Tips. My first Roadster Q249 FDF had a metal cylinder with a chamois washer which slid into the neck and stopped the slop
      Sorry but I'm just going out and away for here days, I'm sure the details are there in an early magazine...alternatively when I get back I could put you in touch with the current owner of the car.
      EDIT Crossed post with DB, yes that is in the same place as Q249
        • 930
        Mine's in a similar position to David's. I fitted the MX5 device that's supposed to stop fuel sloshing back up the filler neck but it's not 100% effective. I'm thinking of repositioning it up next to the spare wheel or further up on the side perhaps above the level of the rear light.
          Had exactly the same problem with spirited driving. Had a Monza style fuel cap, replaced seals etc but still leaked.
          Ended up raising the fuel filler by about 6" and it solved the problem. I used some hose from CBS.
          The only problem is that there is a hole to filled with fibreglass that needs painting.
          • chris_roadster
            • Dec 2014
            • 5
            I am still in the process of building the petrol tank is one of the next jobs i had already fitted it as the manual says with the filler outlet at the back right but i was advisded to mout the oppostie way with the outlet being on the font left just recieved the hose and filler cap from cbs no holes cut yet
              My tank is from the escort van but turned round and mounted as far to the right as possible then has a sweeping bend coming up to the cap
              • lil_red_roadster
                • 710
                Bit of careless parking there Ben...or did you reach the end of the line
                  Bad planning Jez, The rotary drier socket was in the middle of the garden and in the way, Fortunately I had done the washing and ironing the day before Is it just me that has a problem with the pictures being too big?
                  • scott h
                    • Mar 2013
                    • 670
                    Since I got a new phone with a larger camera I found that the pictures were too big. Now I use a program called paint on my lap top to reduce them by 50% and it works fine. There are probably other maybe easier ways to deal with the pics but it works for me.
                    • Gareth
                      • 502
                      Hi Scott, I couldn't find the programme you use, paint on my lap top, so I Googled it and came up with some, er, interesting sites...
                        You can use http://www.picresize.com/ this allows you to upload your pic, crop add effects etc - you can even do a bulk upload if you wish. Nice little free app.
                        • scott h
                          • Mar 2013
                          • 670
                          Just tried that app and it seems similar to "paint" which is on my windows 7 lap top.
                            • 930
                            This is how I currently have mine fitted, note that the pipe is almost horizontal from the tank to the body. I'm thinking of moving it up onto the back of the tub from the side alongside the spare wheel. The problem is that I'm having trouble locating the parts to complete it. The only way I can find of getting the pipework to head off down toward the tank at the right angle is to use a VW T2 camper van filler neck to body seal. Any ideas/suggestions welcome.
                              That looks remarkably similar to mine, but I have a lid on that box next to the tank, with two filtered fuel lines going in, maybe to two pumps as there's a two way switch on the dash. As for the pipe, I may need to do this as well so will do some research for us.
