Cabrio v8sd1
  • Taylor
    • Jun 2014
    • 2
    Cabrio v8sd1
    Need exhaust manifold pipes, rover engine v8 sd1.
    Re: Cabrio v8sd1
    There are several manifolds for the V8 Rover engine but if its definitely SD1 then ebay item number 301483530221 may help. There are some others for the MGB which fit closer to the block - are you haveing a complete new system?
    • dbazdavies
      • 409
      Re: Cabrio v8sd1
      MGB V8 ones are nice and tight !!!
      • Michael Turpin
        • 172
        Re: Cabrio v8sd1
        I have recently fitted a pair on my roadster, MGB hive MG BRAND NEW MGB V8 STAINLESS STEEL BLOCK HUGGER MANIFOLDS £325 a pair
        [IMG]file:///C:\Users\MICHAE~1\AppData\Local\Temp\msohtmlclip1\ 01\clip_image001.jpg[/IMG]
        • Michael Turpin
          • 172
          Re: Cabrio v8sd1
          The remaining piping was made from six 900 bends (Clamco SSB3890 38mm 90 Degree Stainless Mandrel Bends) £10.25 each - three for each side. These were cut to length and then fastened together using strips of mild steel and a jubilee clip on each side of each joint, this enabled me to remove the three pieces of pipe as a whole keeping them in the correct orientation. The joints were then TIG welded (tacked) at three points to avoid distortions, the clips were then removed and a run of weld ran around the whole pipe finished the job.
          Try looking at http://www.clampcouk.co.uk/exhaust-r...rel-bends.html for various types of bends.
            • 1648
            Re: Cabrio v8sd1
            [ATTACH]5862[/ATTACH]
            Hi Michael. I am still looking for something to replace the failing O/E Marlin manifolds on my Hunter. Any chance you can post some more photos of the above fitted to your car, especially on the driver's side? I believe the engine mountings will be the same as my 3.9i V8 but obviously the steering column and chassis clearance will probably be more of an issue for me. Also details of your supplier would be appreciated. Peter.
            By the way I am assuming that the manifold ports & studs are the same on both the 3.5 and 3.9i engines? Can anyone confirm this? PL.
            • Michael Turpin
              • 172
              Re: Cabrio v8sd1
              Peter your right the down-pipe does come close to the engine mounts on both sides so I altered the mount to accommodate it. It also fouls the right hand side drain tap which had to be plugged.
              I will take some pictures ASAP but I am in the middle of a gearbox change which requires all the exhaust system to be removed which I have just done today !! but the manifolds are still attached so it should be very clear how much room there is.
              I'm not sure if the 3.5 is the same as the 3.9 but I had originally had a pair of P6 cast iron manifolds but they ended up cracking and literally falling apart so I'm assuming that most of the rover V8 variants are the same
                • 1648
                Re: Cabrio v8sd1
                Many thanks Michael. When you take the photos can you please include a ruler in the pics especially if you can take a "front" and "top" view as I need to see the clearance for the steering and the chassis. I have an MOT 6th Feb so hope to get it sorted by then . Peter.
                • Michael Turpin
                  • 172
                  Re: Cabrio v8sd1
                  Peter here are a few pictures taken today before you asked for a ruler (good idea) to be included
                  let me know if you need any with a rule, you can get an idea as the manifold tube is 44mm dia
                    • 1648
                    Re: Cabrio v8sd1
                    Hi Michael.
                    Many thanks for the quick response.
                    Unfortunately my engine mounts are under the centre so it looks as though it will foul the down pipe.
                    Photo of my O/Side one attaced:
                    I have seen other tubular manifolds by Rimmers and one on the Locost forum but they also will either foul the engine mount, the steering column or the chassis at the front.
                    Back to the drawing board I guess.
                    Peter.
                    • Michael Turpin
                      • 172
                      Re: Cabrio v8sd1
                      Peter, its a shame because the new manifold and pipework had a marked effect on the overall running and performance, however you are right I had to modify the engine mounts moving them about 30mm off their original position and the steering linkage even though the linkage on a YKC is lower down I had to put another UJ in the route
                        • 1648
                        Re: Cabrio v8sd1
                        Hi Michael. That's an interesting set up. Just for my future reference can you take another photo of the steering where it runs along the chassis, where I guess you will have put some extra support / bearings of some kind?
                        Also where did you get the extra universal joints? I may well have to use something similar if I ever find an off the shelf system that would fit "if only the steering was out of the way". Peter.
                        • ruby131
                          • 163
                          Re: Cabrio v8sd1
                          Hi Peter, that looks like a Cortina part to me.
                          • Michael Turpin
                            • 172
                            Re: Cabrio v8sd1
                            Peter the extra joint was from a Ford Sierra which I had left over from when I built the car 20 yrs ago.
                            The modified shaft was made from toughened steel the splines being cut on a dividing head and milling machine, the long shaft runs along the length of the chassis and is supported in a nylon block just behind the second joint and then joins a third joint at the steering rack.
                            • scott h
                              • Mar 2013
                              • 670
                              Re: Cabrio v8sd1
                              Hi Peter, Car Builder Solutions do a good selection of parts to make up a steering column, including various U/Js and splined or triangle shafts. Scott.
