ouch!!!
  • Alan B Gloucester
    • May 2012
    • 92
    ouch!!!
    Ouch!!! Ebay 191411032028. Everyone's worst nightmare.
  • tobyholland
    • Apr 2012
    • 8
    Awww
    not good
    http://www.ebay.co.uk/itm/Marlin-kit...:SS:SS:GB:1120
      Re: Awww
      I was just looking at that, looks like a fuel fire caused by the carbs?
        • 931
        Re: Awww
        Yes I've seen this sort of thing before. I was once overtaken by a Dutton on the A13 only to find it ablaze 10 miles down the road. There is a common fault on the twin choke down draft carbs used with the pinto and crossflow Ford engines where the brass tube used to connect the fuel pipe to the carb works loose and falls out spraying fuel all over the engine bay. I've had this happen once and luckily it didn't catch fire my roadster just spluttered to a halt. This reminds me that the oil pressure cut off switch is a good addition for the electric fuel pump that I've just fitted!
          • 931
          Re: Awww
          PS running with side drafts without air filters is also a bad idea. The air filter also ensures that any spit back through the carbs is contained.....
          • Motormouse_67
            • May 2014
            • 123
            Restoration project !!
            • fredsajs
              • 131
              Re: Restoration project !!
              Yesterday I had smoke pooring out of rear mine at 45 mph so my passenger informed me so I attempted to pull over. But it ground to a halt befor I had time to.
              Got out rushed to rear with engine running to find smoke billowing out of nearside rear wheel arch.
              Pannick,I told passenger to bail out.
              Smoke deminished engine still running ?, funny! air smells awlful ?.
              INvestigated area found rear wheel red hot.
              I then remembered garage whom fitted tail end gearbox seal said handbrake well oiled due to old leak, so we readjusted slack in handbrake cable for you.That was 10 miles ago.
              Crawled under and reslakened it off. and drove home fine.
              Funny he thought he was doing me a good turn !, not driving me to panic instead!!.
