Radiator fitting
  • Patrick
    • 469
    Radiator fitting
    I have a Marlin supplied BMW radiator. It looks completely different from the one in the donor E30. I've got a big Y shaped bracket and 2 S shaped brackets. I can't figure out how these attach to the radiator and then to the car. Has anyone got any pictures of an installed radiator that I could have a look at?
    Thank you,
    Patrick
    www.msportster.co.uk
    http://www.modelog.co.uk/
    http://www.mustang67.co.uk/
  • Patrick
    • 469
    Re: Radiator fitting
    I've figured out how the Marlin brackets work, but found there was not enough room of the electric fan in front with them so I made my own. Pictures here (including test fit of Marlin brackets on the previous page:
    http://www.msportster.co.uk/detail.asp?cat=7&offset=96
    • r.norman227
      • 16
      What I would like to know is if anyone has fitted the standard e30 325 rad? It's a crossflow design and in theory more efficient than the one Marlin supply which is a traditional top to bottom flow. Also has anyone had any experience of any overheating problems?
      BR Robin
      • r.norman227
        • 16
        Cracked it. Close examination of the BMW ETK shows that the Marlin supplied radiator is in fact from a pre97 BMW. The design then changed to the one I have from my donor car which is later than 97. Solution - get a pre 97 radiator, although it dosen't seem to be as good a design(not crossflow) :-(
