Starter Solenoid wiring - 1300 A series engine
    • 2454
    Its been one of those days.
    I need a picture and explanation of the Starter Solenoid connections for an A Series engine.
    It doesn't say what goes to what teminal in any of my manuals and I have tried looking up on the web but no go there either.
    Can anyone help.
  • Robert in Cumbria
    • Mar 2012
    • 603
    Re: Starter Solenoid wiring - 1300 A series engine
    Assuming you are using a square or round separate solenoid. Heavy power cable seems to work on either bolt terminal. The brown or brown/white power lead goes to the battery side and the white/red lead goes to the solenoid operating Lucar spade. If you have a ballast resistor than I think it's a white/yellow lead which goes to the other small connection on the solenoid or the starter lead if there isn't a fourth connection for the ballast by-pass lead.
    I will have a diagram but those are the connections for the solenoid.
    • CABRIOBOB
      • 478
      Has your got a feed from the battery and then to the startor motor and a small white/red wire spade from the ign switch and 2 spade brown wires 1 from a fuse and other to the alternator or control box if using a dynamo
        • 2454
        Once again many thanks for your help
