Manifold
  • ruby131
    • 163
    Manifold
    WANTED,,, Combined Inlet exhaust manifold for 1300 with vaccum outlet. contact Chris on 07882594331 or mail [email protected]/
  • ruby131
    • 163
    Re: Manifold
    Correction to Manifold Wanted contact number is 07881594331
      Re: Manifold
      One of these???
      Part number is cast on 12G3538
      • ruby131
        • 163
        Re: Manifold
        Thanks Steve looks like will check it out later Cheers Chris
        • ruby131
          • 163
          Re: Manifold
          Problem solved item now found Thanks Chris
            Re: Manifold
            Chris, what was the problem with your old manifold or are you changing carbs around?
            • ruby131
              • 163
              Re: Manifold
              Hi Steve,tightened up the downpipe clamp and the flange shattered !
