Radiator grill wire
  • christopher.bogue2011
    • 113
    Radiator grill wire
    O.K. Long shot but does anyone know where to get the wire from that was used by Marlin to make up the roadster grills?
    • 2454
    Re: Radiator grill wire
    Don't have the wires but here is one I made earlier.
    Yours for £10 + Postage or I will bring it to Stoneleigh if your going?
      http://www.wovenwire.co.uk/cargrilles.htm or http://www.themeshcompany.com/acatal...ille_Mesh.html might be what you need Chris but the one above looks perfect
      • tim hawkesworth
        • 178
        I used the woven S.S. wire that Cameron refers to on my Sportster and Berlinetta. Marlin used the same mesh on my Hunter.
        It is not easy to cut but looks the part.
          • 113
          Hi Adrian,
          Sorry I haven't been in touch. If your grille is still available I would like to buy it from you. I aim to be going to Stoneligh but not sure which day. At the moment my Roadster engine is still in bits but hope to have it ready. Will you be there on both days?
          Chris
            • 2454
            Hi Chris
            Yes I will be there both days and I wil be brining a few other bits and pieces that are surplus to requirements.
              • 113
              Hi Adrian,
              Thats good news. I will look forward to seeing you there.
              Chris
                • 113
                Hi Adrian,
                Just wanted to say thank you for bringing your spare rad grille to Stoneleigh. I hope you were able to sell it in the end?
                With regards to the coil-over dampers I will at some stage do a write up on how I did mine for those interested.
                It was good to meet you.
                Regards,
                Chris
                  • 2454
                  Hi Chris
                  No hassle.
                  It was good to meet you and see your excellent Roadster.
                  Happy Motoring.
                  • Kahawi
                    • Jan 2018
                    • 159
                    My Hunter grill is looking a ‘tad’ weary and in need of a clean-paint-polish job. It’s non-magnetic, and seems quite solid, so I’m ruling out aluminium, thinking polished stainless?
                    Any advice on how complex it is to remove? i.e. an over-winter project or next Sunday morning before Church? It looks like a lot of masking to repaint, has anyone already tackled this task please.
                    Cheers,
                    Colin B
                    • peterboat
                      • Jun 2016
                      • 232
                      Its glued in place or it was on mine, I had to remove the the whole fibreglass shell which is a bit of a pain to say the least
                      • stephenlilley
                        • 102
                        I had this problem recently, So rather than go to all the grief of trying to fit a standard type of grill, I removed the old grill using an angle grinder. carefully pulling out the tangs from the cowl. I then removed the frame and fitted clips from headlamp grill covers, made a new grill to fit flush within it and simply clipped it into place. I now have easy access to the remote fan and the radiator.
                          • 2454
                          Now that is a good idea.
                            • 2454
                            Where did you get the grill?
                            • stephenlilley
                              • 102
                              Bought it from The Mesh company
                              Unit 1
                              Farrel Street
                              Warrington
                              Cheshire
                              WA1 2WW
                              Phone. 01925 406640
