Spares for Triumph based Roadsters
  • Peterx
    • 361
    I saw this and thought it might be of interest to owners of cars fitted with Triumph parts.
    http://www.madabout-kitcars.com/foru...referrerid=181
    ...peter
  • ruby131
    • 163
    Re: Spares for Triumph based Roadsters
    Triumph spares............ A friend in Tavistock, Devon has literally sheds full of new and used Triumph parts, everything imaginable. Engines, overdrive gearboxes, suspension, diffs, instruments ect. you name it. His name is Steve and can be contacted on 01822614171. always worth a call. Cheers Chris
      All very useful info
      Many thanks.keep em coming
      Ben MOC TR Tech rep
        I received this email from Max at totally triumph...
        Hi Cameron
        I have several chassis, running gear parts (inc. some used weak rear springs, ideal for light cars). Some new stock (some fast moving stuff has gone). Loadsa seats (Triumph & after market, but they need recovering). Breaking a Spartan (I believe the front wings are the same, sometimes the rear can be modified). Most of the Triumph engines have gone except a very quick 2.5 with a saloon OD gearbox modified to fit in Triumph chassis.An alledgedly rebuilt Vit 6 1600 engine. 2 x 3.5 Rover V8 (1 on SU & 1 on Holly) both running but ideally need rebuilds. A fully rebuilt Rover 3.5 with rebuilt 5 speed box (currently on ebay 300666781631) Used heads, cranks, inlet manifolds with carbs (1300cc twin 1.25 SU) + others. 2 litre inlets with carbs, exhaust manifolds,(4 & 6cyl) some exhausts new & used. New engine parts (shells, thrusts, oil pumps, gaskets, seals,valves, exhaust clamps)
        www.totallytriumph.co.uk [email protected] [email protected] 01565 777577 07860 26 62 62
        Thanks again
        Max
