Cabrio Heater Blower
  • bryannewell
    • 331
    Hi folks
    I need to replace the faulty Heater Blower Motor on my Cabrio
    Anyone know of a source/have one they are willing to sell on?
    There are 2 on ebay but look slightly different,mine has a 3speed resistor clipped to the top.
    I have attached a couple of pics if anyone can advise of model year?
    Bryan
  • Frans de Vries
    • 14
    Re: Cabrio Heater Blower
    Looks exactly like mine.
    My donor was a 1989 Scorpio
      from memory looks like mine too, from 1986 Sierra. They are probably very similar.....
        • 1649
        From memory it looks like the one that was fitted on my old 1987 2.0GL Sierra. That certainly had the three terminal resistor mounted in the middle. Peter.
        • bryannewell
          • 331
          Picked up one from breakers today!
          Can anyone advise the correct wiring layout for a 3 speed set up
          regards
          Bryan
            I can't remember exactly. I didn't use the Sierra control but one from a Escort, but the principle should be the same.
            Each terminal will give you a different speed setting, so the easiest way to work out what needs to be connected up is to connect the body of the heater to a battery -ve terminal and connect each of the 3 terminals to +ve to see which speed setting is which.
            You then need to determine which of the 3 wires from the fan speed switch is which. You can either do that using a meter and going through the switch settings. If you haven't a meter of you could improvise using a 12v light bulb to show you which wire relates to whcih setting.
            • keith_h
              • 549
              Hello Bryan
              The attached is the Ford wiring diagram for Sierra '91 - hope it helps
              Keith
                • 1649
                Hi Bryan. There are two wire wound resistors in the unit, one with thick wire and one with thin wire, both have a common terminal (the feed from the battery). The switch needs to select either the thin wire (slow) or the thick wire (medium speed) or the common battery feed terminal ( i.e. no resistor in circuit = fast speed). Hope this helps as it should enable you to choose a suitable switch. I can't remember if this was switched through any relays on the Sierra so check the switch has a high enough rating if you wire it directly in the circuit. Peter.
                The switch also needs a fourth "open contact position for "off". Peter.
                Last edited by greyV8pete; 29-01-12, 12:01 AM. Reason: Fourth switch position added.
                • bryannewell
                  • 331
                  Hi Keith
                  Thanks for the diagram but it does not tally with what I have as does'nt anything in the Haynes manual!
                  Peter
                  I think I have worked out what I need including the relay.
                  My problem is if I put a feed to any of the resistor connections nothing happens but a direct feed to blower works,so the motor is ok
                  The resistor looks perfect so I guess I am missing something!
                  Still untill I can get my head around it at least I have a single speed blower which is an improvement over no blower at all!
                  Thanks for all your help
                  Bryan
