What the hell is this
    • 2454
    OK you budding Marliners what is this. I found it while routing through the bits that came with the Marlin Roadster SWB. The kit is a MK2. Any ideas? Adrian
  • FranklinLeicester
    • 380
    Re: What the hell is this
    Adrian, if you had asked this question 3 weeks ago I wouldn't have known the answer. It is a Morris Marina A-series near-side engine mounting bracket. If you cast your mind back 2 weeks I was at the SHEB meeting in a VW convertible, my Marlin was off the road because I had a broken bracket as you have just found. I welded mine up the following day but don't yack it away, I'll have it off you sf you don't want it.
    Franklin, Leicester
      • 2454
      Well because you solved the mystery I will gladly let you have it. I have weighed it and it will cost around £5 to send. Send me your address to adrian_j_bull(at)hotmail.com and if you are ok with the postage I will send it to you. Well done. Adrian
