Crazing on paintwork
    I have got a few chips on my roadster and they have started to craze is there anything I can put on them to stop them spreading too big?
  • rob
    • 11
    Re: Crazing on paintwork
    If the crazing is on the fiberglass the only way to stop it is to make a grove and fill it with resin it means respraying but it sorts it out.
      the way I was told to do it was to drill a hole on each side of the crack/craze and as Rob says make a groove/cut the section out and refill with fibreglass & then respray.
      I bought a new wing instead (ok, so there was a sizable rip from an accident earlier in the cars life as well).
        I prefer salt and vinegar on my chips! No seriously try Cpt Tolleys Creeping Crack Cure its easy to use.
          Thanks for all of your suggestions. Thanks especially to Ben (SE London) for his recommendation of capt. tolley's creeping crack cure, it really does work, brilliant stuff! Thanks
