Berlinetta C20XE conversion
  • g984xrg
    • 1
    Hello all,
    I am looking into doing the above conversion and would like to know if anyone has done this already, i usually do other vauxhall conversions so this is something new for me.
    Any help would be great.
    Thanks alot David.
    • 590
    Re: Berlinetta C20XE conversion
    Hi David,
    I think you are probably the first to opt for this engine in a Berlinetta. In fact, probably any Marlin. It is a popular choice though for the locost / Caterham / Westfield boys. I would try the locost forum for any technical questions you have. I did consider this engine for the roadster but ended up going Fiat twin cam. I found SBD motorsport really helpful.
    http://www.sbdev.co.uk/SBD%20Motorsport%20Display.htm
    They have all the bits for RWD conversion.
    • robcawte
      • 68
      Hi David
      I don't have a clue about this engine, but I'm going to look into it. If you do this engine swap. keep us posted, thanks.
        Great idea...I considered the Vauxhall 2.0 for my Roadster but went Rover in the end. Why not make it simple & buy a complete 2.0 Omega and use the entire Ecotec engine/box combo? Almost an XE...but not quite...and having the donor car can make the process of wiring a little easier.
        Good luck...and look forward to the write-up.
          • 1237
          Hi David, I have read about a Vauxhall powered Berlinetta, but I do not think it was this engine. Also Mark Matthews built a Sportster with a Vauxhall engine, but again I am not sure which engine. Would you use the Vauxhall gearbox or use a bell house to convert to a Ford box? I would be interested to hear of your progress.
          Danny.
            • 590
            Sportster had a V6 Omega engine and gearbox. It was yellow. Reg number R404 NTA.
