Marina/Ital switches
    • 2814
    Just found this, new to me, switches that are "repro" for Marina/Ital dashboards
    http://www.demon-tweeks.co.uk/Motorsport/Electrical_Components/Switches/Trillogy_Illuminated_Rocker_Switches/1282/1679
    Rgds
    DC
    • 931
    Re: Marina/Ital switches
    I've just noticed that Car Builder Solutions are supplying a larger range of the same switches http://www.carbuildersolutions.com/uk/rocker-switches and they also supply an indicator column switch with dip/main beam changeover and a horn switch as well http://www.carbuildersolutions.com/u...assembly-black looks like its about £64 to replace the functions of the old Marina column switch with a new set...
      Caution on two counts.
      Not at all sure that the self cancelling mechanism will work.
      Check the current rating of the contacts esp for headlights and main beam, Marinas did not fit relays so the switches take full current.
