Oil Cooler Pipe Connections Rover V8 3.9i
    • 1649
    I need to put an oil temperature sensor in the outlet hose from the oil filter housing to the remote oil cooler on the V8 3.9i (L/R Disco engine - Serpentine drive belt) in my Hunter. One pipe exits vertically downwards (which I suspect is the delivery side) and the other enters horizontally facing the offside (which I believe is the return)? Is this corrrect? There do not seem to be any flow direction arrows on the casting to confirm this.
  • djj_engineer
    • 405
    Re: Oil Cooler Pipe Connections Rover V8 3.9i
    Hi Peter
    Not quite what you are looking for, but certain RR/LR/Discovery's have an oil pressure gauge sender unit that also has a temperature sender.
    They are more expensive than the straight pressure unit.
      • 1649
      Hi Derek. That's an interesting one. Unfortunately I can't find anything listed anywhere. Do you have any further info on this part? Peter.
